48-1270 finally assembled and completed with video
Hello I just finished my Philco I feel lucky , it was free , I used sanding sealer and stain and rustoleum specialty lacquer spray and painted the changer with rustoleum paint also
[Image: http://i168.photobucket.com/albums/u166/...000418.jpg]
[Image: http://i168.photobucket.com/albums/u166/...000425.jpg]
[Image: http://i168.photobucket.com/albums/u166/...000424.jpg]
[Image: http://i168.photobucket.com/albums/u166/...000422.jpg]
http://www.youtube.com/watch?v=ALxJf96yJcQ&nomobile=1
[Image: http://i168.photobucket.com/albums/u166/...ary-74.jpg]
[Image: http://i168.photobucket.com/albums/u166/...000420.jpg]
Looks great. Good job!!!
-Keith
Double snazzy!
Icon_thumbupIcon_thumbup
Beautiful job, and it sounds great!
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
