Bakelite Block Question
Hi Guys,
One quick question, is a bakelite block labeled 3903DDG the same as this configuration that I found online?
3903-DG 2 .01 .01
73 de,
Gary/N9VU
That's ODG ("oh-dee-gee"), and yes, same configuration. The 'O' simply means that this "universal style" block used hi-temp wax impregnation. See page 2-3 in "Philco Condensers and More," 2nd. edition by Ray Bintliff. Info on my bakelite block condenser page.
Chuck Schwark Wrote:That's ODG ("oh-dee-gee"), and yes, same configuration. The 'O' simply means that this "universal style" block used hi-temp wax impregnation. See page 2-3 in "Philco Condensers and More," 2nd. edition by Ray Bintliff. Info on my bakelite block condenser page.
Thanks Chuck. Your site is always the first place I check. Appreciate the information.
73 de,
Gary/N9VU
There are currently 4391 online users. [Complete List]
» 4 Member(s) | 4387 Guest(s)
AvatarAvatarAvatarAvatar
