Volume control, Model 16
I'm restoring a Model 16 and need a good volume control / switch. This Code 125 model has a 2 meg pot with two wipers(!) Apparently one of the wipers goes to the bass compensation resistor / cap, and it appears to be inverse to the main wiper. This is probably a well discussed issue -- anyone have a good solution? Thanks!!!
David Sligar
Well, gotta get a capacitor in line with the output stage, and the more you cut it off with lower values, more treble. Larger coupling favors bass response to a point. If the tone pot is partially open. might be the case.
Anybody know where to get a replacement pot? Only other thing I can think of would be to use a dual pot -- 1 meg would probably be OK -- with a switch.
Any other ideas?
Thanks!
Contact Mark Oppat at the web address below.
http://oldradioparts.net/controls.html
You could use one that is tapped. It acts as a loudness control. Give a bit bass boost at low volume.
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3302 online users. [Complete List]
» 1 Member(s) | 3301 Guest(s)
