Interesting Philco article
This appears in today's [02/27/07] Sandusky Register about the old Sandusky, Ohio Philco plant.
http://www.sanduskyregister.com/articles...122871.txt
Ernie K8KHH
Ernie Sibberson
Firelands Vintage Radios
http://www.firelandsradios.com
Nice history piece Ernie. Icon_smile
Enjoyed it.
Yes, thanks for sharing that!
Brian
There are currently 8592 online users. [Complete List]
» 1 Member(s) | 8591 Guest(s)
