philco 41-290 toner
i am refinishing a philco 21-290 cabinet and wonder if anyone knows which brand and color of toner in spray cans best matches the origional tone.---------------- thanks
Yes - Mohawk Medium Walnut Tone Finish, or Mohawk Medium Brown Walnut Ultra Classic, overall. Unlike some Philco consoles of that period, this one is a "monotone" (single color).
thanks ron ------------lot of hardwood in this cabinet and it is one of my favorite philco models of the 1940 era along with the 40-190
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
