Philco Demonstrator
Is anyone else out there familiar with something called a Philco
demonstrator besides me?
The Philco Demonstrator was a industrial Philco radio made into a large
breadboard for electronics instruction in High Schools and other educational purposes circa mid 1950's. I have a partial picture with
students troubleshooting one at Salem Vocational High School in
Salem, Mass my Electronics class in 1965. I just have to figure out how to load it to this site, can I do it through Flicker?
Yes, you can.
More details:
http://www.philcoradio.com/phorum/showthread.php?tid=29
http://www.philcoradio.com/phorum/showth...p?tid=4371 (these instructions are for Photobucket, but Flickr should have detailed instructions as well.)
Philco 91 Tuning Condenser
There are currently 3696 online users. [Complete List]
» 1 Member(s) | 3695 Guest(s)
