Philco model 66
Does my Philco 66 have an oscillating coil - if so, what does it look like and where is it? Thanks, Phil
Yes. It is item 16 in the parts location diagram. Schematic is here.
http://www.nostalgiaair.org/PagesByModel...013827.pdf
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
Philco 91 Tuning Condenser
There are currently 9392 online users. [Complete List]
» 1 Member(s) | 9391 Guest(s)
