Just finished RCA globetrotter
I thought I would post some photos of my latest finished radio.
It's an RCA 12 tube model A-33 Globtrotter. The cabinet work was easy. I recapped the radio,and changed the 1 meg resistor for the eye tube and it works..Sounds real nice with a phone hooked up..
It still has a slight hum between stations but with my knowledge of electronics it will have to do until I learn more. Here are the photos.
[Image: http://i318.photobucket.com/albums/mm405...A008-1.jpg]
[Image: http://i318.photobucket.com/albums/mm405...Medium.jpg]
[Image: http://i318.photobucket.com/albums/mm405...012001.jpg]
Wow, that looks fantastic! Great job!!
- Geoff
Looks great.
Beautiful job.
That cabinet takes my breath away. Beautiful!
Dan, you have a knack for finding sets with very good-looking, stylish, beautiful cabinets. Good job! Icon_thumbup
Beautiful set! Nice job with it! I'm impressed to the point that I have added it to my "bucket list!" Icon_thumbupIcon_thumbup
Your satin finish is the perfect touch. Just spectacular.
Keep one hand in your pocket
Thank you for the comments. I run across these radios at garage sales and flea markets and by word of mouth. The cabinet part is easy but the chassis is another story,so I keep reading ''The Elements of Radio''
I also put a few adds on Kijiji with good response.
Here is my latest find..It is a RCA and the model is ''Master''
I picked it up at the local flea market for $30.00. It has now been racapped and polished up. Before and after photos
[Image: http://i318.photobucket.com/albums/mm405...edium2.jpg]
Philco 91 Tuning Condenser
There are currently 10508 online users. [Complete List]
» 1 Member(s) | 10507 Guest(s)
