CHASSIS CLEANER
Icon_confused: WHAT IS A GOOD CLEANER TO CLEAN UP A DIRTY TARNISHED CHASSIS?
I use GoJo hand cleaner (white) and 00 steel wool. But you have to be REALLY CAREFUL that any (steel) residue is removed. Try and ensure it does NOT go below the chassis (any holes, etc). Dave
There are currently 5759 online users. [Complete List]
» 4 Member(s) | 5755 Guest(s)
AvatarAvatarAvatarAvatar
