Anyone have a 41-608? help please
I have a 41-608 that I recapped and I believe I have a cap with 1 leg in the wrong position. The unit worked after I replaced all the coupling caps and I foolishly moved one leg of one of them and now does not work. I have been over the schematic many times and can't seem to find it. This was a stupid mistake and I am fairly new to this. Anyone have one of these and can get some pictures of the underside of the chassis where the couplers are soldered? I know its a long shot but have to ask. Thanks in advance for any help. This is a wonderful radio and want to see it live again!
Where is the side that is connected connected to???
They are all hooked up, and according to the schemantic, correctly. I know theaudio side is working, I get a nice hum when I touch the volume control.
What cap is it?
Its one of the. 05s that run beside the XXL tube and the 1st. Rf tube 7b7. There is a strip of tie points and I think Its one of those.
Also, this is a 122 model.
Give us a reference number from the schematic for the component(s) in question, so we are starting from the same place.
The speaker table error?
Philco 70 antenna lead
There are currently 6744 online users. [Complete List]
» 2 Member(s) | 6742 Guest(s)
