Threads: 103
City: Calgary, AB, CA
This had been on kijiji for about a week when I finally saw it. I drove the 300 miles to pick it up. The finish is in very very good condition,and the radio does work but it will need a recap and the motorboard needs to be cleaned.. All in all it is a nice radio,,one that I have been looking for.
[Image: http://i318.photobucket.com/albums/mm405...Medium.jpg]
Threads: 562
Itsabeaut! Congrats! 300 miles....well, that's what I call determination!
Threads: 92
City: Clayton, NC
Nice looking set!! Not easy to work on, though.....
Threads: 31
City: Lapeer
State, Province, Country: MI
Gorgeous. It'd be nice to see a close-up of the dial... Regards, Joe
Joe
Threads: 103
Joe ,,I will take a few photos of the dial and post them tomorrow .. Thanks for the comments.
I have the motorboard out and there are about ten wires that have to be unhooked ,in order to get it out. It's going to be quite a project.
Threads: 31
City: Lapeer
Thanks Dan, keep us posted! I've become interested in RCA products when I recently obtained a 77V2 that had been in my Grandmothers house. The cabinet was well cared for, though it'll need a complete recapping and some rewiring. I'll post a photo when I get a moment. Best Regards, Joe
Joe
(This post was last modified: 08-05-2012, 08:40 AM by Joe Rossi.)
Threads: 103
Joe ,here are some photos of the dial and I am including one of the lable that is on the bottom of the motor board..
I can see that this one is going to take some work.. I don't mean a lot of problems but there are a lot of wires that seem to go everywhere.. If anyone has a wiring diagram of the motorboard I would like to see it. I do have the schematics but I don't have anything showing how the mororboard connects to the amp,and someone had disconnected the wires....Dan
Threads: 31
City: Lapeer
Dan, Thanks, this is really awesome, and the detail on the wood is great. A really great find! Joe
Joe
Threads: 15
City: Ortonville, MI
You'll find that this is a very nice set. I see that someone has refinished the cabinet, but not a horrible job.
When the pickup is back in good shape, the output of this set on phono is very good. While this set is similar to the RCA Radiola 86, they put a hotter coil in the pickup than was in the Radiola 86. Both the VICTOR (The RCA name was not on the RE-57; just Victor) RE-57 and the Radiola 86 were sold as parallel product lines in the stores.
There should be a single button carbon microphone, and a pickup head weight with the set for home recording (which can't be done today, anyhow). There is a position on the selector switch on the motor board for "Public Address" if one cared to blab over the radio with the mike.
As on most of the RCA amplifiers of that day, and considerably later, the interstage transformer will have open windings. There might be a replacement on yours.
Threads: 54
That set may be as late as 1931 if it is a Canadian made Victor. For whatever reason, contractual obligations to dealers I suppose, there were sets marketed under the "Victor" name in Canada as late as 1935. I had a "Victor" 118 and it was from 1934-35, and it did not have the RCA name or logo anywhere on it.
Be careful lifting that set, A fellow collector I knew in the Edmonton area nearly gave himself a hernia trying to move one up the basement stairs.
Threads: 103
I have the motorboard out and I cleaned it up.. When it was refinished ,no one had marked any of the wires that go to the motor.
I do have all the schematics for the radio but none of it contains any refrence to wiring or connections to the motorboard.
There are also wires that go to the switches connected to the turntable for the shutoff controlled by the arm..and I don't know where to hook them up.
If anyone has information at all [/i]about these connections please email me ,,
Thanks Dan
(This post was last modified: 08-18-2012, 10:32 PM by Dan Walker.)
Philco 91 Tuning Condenser
I thought you meant the actual dial....there are rivets.morzh — 08:42 PM |
This is what I meant.morzh — 08:37 PM |
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
There are currently 5530 online users. [Complete List] » 3 Member(s) | 5527 Guest(s)
