Fred's 23X, recent pics
The top five photos in the photobucket link below are the most recent ones. Fred is definitely doing a rare Philco proud!!
http://i1194.photobucket.com/albums/aa37...resto1.jpg
OK, lets try this link for all the photos....
http://s1194.photobucket.com/albums/aa37...lco%2023X/
I would die for a spray booth like that. Very nice job.
Jerry
Just out of curiousity is he spraying the toner in those photos? That looks like an automotive spray booth by the way, one you can drive cars into.
Correct on both.
I hope he puts several nice coats of glass laquer on it, old radios just don't look right with a matte or satin finish, they had more of a shiny but burnished look to them originally.
Philco 91 Tuning Condenser
There are currently 5801 online users. [Complete List]
» 1 Member(s) | 5800 Guest(s)
