Grunow Model 1191 -11G Chassis
Does anyone have a copy of the schematic for this radio that would be willing to email to me? For some reason it is not listed on Nostalgia Air.
Bob
Bob,
There is a Beitman schematic available in Vol 1, 1926-38, page 75:
http://makearadio.com/beitmans/index.php
Carl
Northern Panhandle, WV
thanks Carl
I went and downloaded the Biemans but the schematic has a partial blank spot and all I really need to know is the value of the electrolytics so I can replace them. The rest should be easy to figure out.
Bob,
PM me with your email address and I will send you the Rider's info.
Carl
There are currently 3638 online users. [Complete List]
» 2 Member(s) | 3636 Guest(s)
