Threads: 9
City: Rockwall,Tx 75087
State, Province, Country: TX
Jerry: Thanks for the idea.. no guts no glory!! I used your method and changed all of the caps. It improved my band width on the upper 570k end some.. Not sure why. I did note the 1Uf cap was reading 1.6Uf.. Now I still need to work on alignment if I can figure that out, and sort out the tuner eye feature. It lights up and changes width when I select LD vs Local switch but not much in the middle .
City: Sedona, AZ/Placentia/CA
Radio Guy, nice job! Bob, sorry this was directed a little from your original post, but nice to have someone doing something along the same lines. Still watching how your doing. Another week on a different project and on to my 111 and it's big cap can. Nice to see Radio Guy dive in and lack fear!
Jerry
PS: Radio Guy, time to start a new thread on any other problems you have with your unit. Just go to the electronic restoration forum and hit new topic. Many will be able to help you with your eye tube issues and any others you have. JH
(This post was last modified: 07-28-2012, 11:35 PM by jerryhawthorne.)
Bandersen, awaiting any more updates on your restoration. Where are you?
Jerry
Threads: 43
City: Chicago, IL
I'm here, I just don't have any updates on this project. I've been too busy with work and other projects. Don't worry , I'll be back at it soon.
Threads: 43
City: Chicago, IL
After a long hiatus, I'm finally back to working on this set
I carefully traced out the wiring for the replacement Wheeler speakers and hooked them up.
[Image: http://farm9.staticflickr.com/8355/83360...7882_c.jpg]
Then, I populated all the tube sockets and flicked the switch.
It's alive  Plenty of volume, but it's not as sensitive as I expected. Also, the shadow meter isn't working very well. I'm not sure about the condition of all the tubes so I'll test them before moving on the checking voltages.
[Image: http://farm9.staticflickr.com/8081/83360...1655_c.jpg]
(This post was last modified: 01-02-2013, 07:47 PM by Bob Andersen.)
Threads: 18
If all else fails, these guys probably have the bulb you need:
http://www.bulbman.com/
Threads: 43
City: Chicago, IL
Another problem I'm having is that after playing about 3-5 minutes, the volume drops off significantly. All tube tubes tested fine so I checked all the voltages.
Most are fine but the grid bias on the 1st and 2nd audio are 10 times what they should be. 0.4 => 5 and 0.2 => 5.
The RF tubes is a bit off as well, but not nearly as much.
I do have a few original dogbones left in the set because they test fine. I'm thinking they may drift off value as the set warms up so I'll try replacing them next.
[Image: http://farm9.staticflickr.com/8504/83390...a21b_b.jpg]
(This post was last modified: 01-02-2013, 07:31 PM by Bob Andersen.)
Had the same problem on my Philco 90. After doing a little monitoring with my scope and generator, it was not in the amp section but in the front end. Well tubes tested good, caps were changed and resistors checked fine. I just replaced the resistors and all was well. Can't tell you the one that was the problem but seems as was suggested sometimes the old ones work well until a little heat. Just a suggestion.
Jerry
Threads: 92
City: Clayton, NC
I found that to be true with the model 111 and model 112s I have done. The resistors, especially the higher wattage ones, are un-reliable and should be closely scrutinized. I started automatically replacing them if they were over 10%.
I am still cleaning/polishing the chassis components on my model 15, but when I do start the electronics I will do the same.
Come to think of it, I need to get some pics of the progress on the 15 here on the Phorum.
Threads: 43
City: Chicago, IL
Well, I replaced every resistor and it made no difference. Next, I tried swapping around the 39/44 tubes and it seems to be making a difference even though they all test well into the good range on my Hickok 600A. I'll go digging for some spares I think I have stashed away somewhere.
Bob, I did also replace one tested good tube when I did the resistor change at the same time. Not certain which did it but not being that curious I just said "It Works". Should probably tried the other tube but at that point, just happy. Might sell that tube to someone else, after all, it tested good.
Jerry
Threads: 54
Maybe it's a bad solder joint acting up after the set runs for a while? I would start by re-soldering the grid caps since they are obviously exposed to heat and mechanical stress, don't forget the grid lead and the clip as well.
Threads: 92
City: Clayton, NC
The 36 tube can also be the problem. I have had them test good but refuse to oscillate.
Threads: 43
City: Chicago, IL
Now that I've swapped around the tubes a few times I can't replicate the problem. I'm leaning towards the problem being a bad solder joint or dirty tube socket. I did a quick alignment by ear and it's playing quite well now
Next up I'm going to unmount the tuning cap assembly and replace the rotted mounts. I'll clean up the chassis more while I have it apart too. Once I get it all cleaned and reassembled, I'll do a proper alignment.
Great news Bob and congrats.
Jerry
Users browsing this thread: 38 Guest(s)
What should I offer?
I am not sure what radio it is, but seems like a 1950 AM/FM set. Or from 1948, possibly one similar to 48-1264.
In any ...morzh — 12:44 PM |
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer. Tried searching images, but...nocusr — 12:29 PM |
So, I unwound the coil; it is 700 turns of AWG40 wire. I modeled it on a couple of different calculators and I got about...morzh — 12:29 PM |
Ron
From the conversation, it was my impression he was a pretty old dude who is looking to place his radios in good h...morzh — 12:16 PM |
Philco 49-1040
Yes, and it's surprisingly common for early TVs to be mostly or all original. My thinking is that they were retired ear...Bob Andersen — 11:59 AM |
91H Code 126 Restore
Hi Nick,
Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM |
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM |
I'm pretty sure that the dotted line I circled in an earlier post signifies that it is applicable to the 226 model which...RealRider — 08:05 AM |
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
There are currently 4192 online users. [Complete List] » 2 Member(s) | 4190 Guest(s)
