1000 V Capacitors in 41-250
Threads: 34
City: Raleigh, NC
I'm ordering parts to recap a model 41-250. Three of the .003 microfarad caps are labeled 1000 VDC. These caps seem to be bypass caps in the plate circuits of the 1st audio tube and the push-pull output tubes.
Do these really need to be 1000 volt caps? I'm just a beginner at this, but I've not run across this before.
Edited to add: I did a quick search and found this topic has been asked and answered before. The caps I have are definately Philco -- probably originals (P/N 30-4469 S.)
I guess this means I'll order the 1000 V replacements....
John Honeycutt
If you don't drive your radio at high volume levels, you can get by with the 630V caps in these positions. But it is a good idea to go ahead and use the 1KV (1000 V) rated caps as replacements.
Threads: 3
City: North Las Vegas, NV
I just got a unit like this Model 41-280, where can I get capacitors! I can't find the .003 1000 Volt, and what type should I be looking for to replace these wax paper capacitors. Film Axial ? I really need help with this project.
Also, I lose volume when I use both #41 tubes, but works with just one tube, sounds better but not at full strength.
Anyone with this experience?
Threads: 9
City: Vieques, PR USA
State, Province, Country: PR
Its not necessarily the high volume levels that get ya. A static crash from nearby storms unimpeded by AVC can create quite an audio voltage pulse momentarily and the "kickback" voltage from the audio transformer can soar. I've never had a 630v yellow-cap fail in such an instance but it would be bad form to suggest that as the way to go. If the cap shorts it may take out the output transformer, field coil, etc.
Smart money says overrate the cap. It can't hurt!
OldJack, to answer your questions, one vendor that carries 1000 volt axial metalized film caps is Just Radios. A bit of searching on the web will probably turn up a few others.
As for your loss of volume, could be a bad audio output transformer, or possibly a defective 41. Or both. Testing the tubes and performing a resistance check of the audio output transformer primary with the set unplugged is the only way to find out.
Threads: 18
Don't really know how often you would need above 630 v in an AA5. Different story with caps to curb power ringing ringing or high frequency oscillations on large tube amps without optimal lead dressing, especially home brews. 2.2 KV values are often needed and used here. Been there.
Never ever hurts to use a higher voltage cap. You can always put a couple of identical caps in series (half the capacitance of each, twice the voltage, if you have the space.
Threads: 117
I just finished a full electronic restoration, full recap, and complete rewiring of a Philco 41-280 chassis. It is very similar in my Riders schematics to other similar Philco models of the same year. Didn't find any original Philco wax caps in the chassis rated a 1 KV, period. It is working fine. Sometimes, manufacturers threw in what caps they had available onhand at the assembly line. 630 volt types caps should be fine in both models. Did my Riders schematic miss something? From past experience restoring hundreds of similar circuits, I didn't see anything in the 41-280 chassis that using 630 volt type caps for coupling or bypass would not handle. Just sayin'! The faulty parts in these type sets are the original Band Switches, always worn out! Deoxit & WD-40 can only do so much to restore these type old Philco bandswitch's for sure on these particular models! Been there, done that many times before.
Threads: 13
City: Montreal, Qc
there was one like that in my 47-1230
I got a replacement from radiodaze if I remember well.
-Mars
Threads: 9
Texasrocker Wrote:I just finished a full electronic restoration, full recap, and complete rewiring of a Philco 41-280 chassis. It is very similar in my Riders schematics to other similar Philco models of the same year. Didn't find any original Philco wax caps in the chassis rated a 1 KV, period. It is working fine.
Hi Randal.
Apples and oranges. On the -280 there is no plate bypassing to ground like in the -250.
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
The wires were desoldered from the can, and the capacitors checked. All checked at 0.102 uF, which is correct.
So the c...morzh — 09:41 PM |
Yours probably then the H speaker, same as mine.morzh — 08:39 PM |
Mike;
I would like to have a look at the speaker in my model 96, but the set is packed into a corner in the basement. ...Arran — 08:04 PM |
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
