Philco Wireless Station Setter
Just picked up one tonight, it looks complete and when i slowly powered it up. I was able to pick up a hum on a nearby radio at different spots up and down the dial when I switched the presets. I will recap and try again. This little unit could be useful since I have several radios with presets.
My question is, does anyone have a good scan of the label? Mine is present but in real bad shape. I found some old threads where several members were going to scan theirs in but never saw where anyone actually did. If you have a good scan of the label or have a good label could someone let me know? I would appreciate it.
Thanks
Skip
Skip
I have one, courtesy of Gary Rabbitt who cleaned it up from a scan I made (and he did a great job, too).
Send me a PM with your email address - it is a rather large file. It is in black and white, you'll need to print it onto gold paper which Gary tells me you can obtain at craft stores.
PM sent. Thanks Ron
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6874 online users. [Complete List]
» 1 Member(s) | 6873 Guest(s)
