Finally - a 38-690!
Two beautiful radios,Ron. Great find. Is the 38-690 a restore, a rebuild or......... just leave it the heck alone and enjoy?
Both (37-690 & 38-690) are working radios...but I am thinking seriously about finding some old Philco paper caps, restuffing them and installing in the 38-690. It's worth the extra effort.
With your two big dog Philco's, your McMurdo, and future Scott you can heat your house with vacuum tubes this winter Icon_wink
Yep, a few of the "big dogs" are taking over the console dept. here... Icon_wink
Absolutely beautiful!!
Philco 91 Tuning Condenser
There are currently 4900 online users. [Complete List]
» 2 Member(s) | 4898 Guest(s)
