Model 19 Cathedral Shadow Meter
Hi all,
Would any of you know if the shadow meter that is standard on a Model 19 cathedral chassis is the same as let's say other models? I've some other chassis that contain shadow meters, and the chassis I am dealing with it now has provisions for a meter, BUT the meter is missing.
Thanks for your advice and assistance.
73 de,
Gary/N9VU
Gary,
Philco designed three versions that I know of (see my Service Tips on S. Meters). I believe the type you are looking for would be the early version with the long rectangular box. The Service Tip will give you other models of that early period that would have used the same type you could scavenge or look for junkers.
Chuck Schwark Wrote:Gary,
I'll give the site a look. Thanks Chuck.
73 de,
Gary/N9VU
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
There are currently 3140 online users. [Complete List]
» 1 Member(s) | 3139 Guest(s)
