1955 July issue Philco Serviceman
Hi
I am wondering if anyone happens to have a 1955 July issue of the "Philco Serviceman"
I need a technical article that was written in this issue. I would be willing to buy this entire issue. And if you don't want to sell it, then if could make a copy of it for me, which I would be also happy to pay you for your time and trouble.
Thanks for your help
Rick
Philco 91 Tuning Condenser
There are currently 4664 online users. [Complete List]
» 1 Member(s) | 4663 Guest(s)
