Clear Lacquer On Decals?
I am finishing up a cabinet for a Philco Radio-Phonograph Model 46-1201.
Question: Does anyone know if its OK to spray a couple coats of clear lacquer over the new decals after they are applied? Or will doing that ruin or yellow the decals?
Thanks
A couple coats of clear lacquer are essential to help protect those decals. A careful application of Micro Sol to each decal before applying more lacquer should make them smoother in appearance.
Excellent. Thanks!
Spray it on!
If you are brushing your finish (as I am) please save yourself my headache from last night and spray several protective layers over that decal first.
My decal fragmented badly under the brush, even though I gave it 2 coats of Testors clear lacquer first. Not sure what to do now, aside from whip out the 320 paper again...
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2191 online users. [Complete List]
» 4 Member(s) | 2187 Guest(s)
AvatarAvatarAvatarAvatar
