  • 2 Vote(s) - 2.5 Average
Philco 40-140 Field Coil Replacement
#46
Thanks again. It's playing great, and with the price of new standard variacs down, I hardly ever plug in these oldies without one--especially the ones with transformers. I run at a constant 108 volts for safety. ciao !!!
#47
Hopefully this thread still has some life. After replacing the field coil with the resistor and installing a 4'' permanent magnet speaker, I was not happy with the cheap sound, so recently I changed to a 6'' speaker. The set picked up hum when I did that, so I had to increase the size of the second power cap from 4 uf to 16 uf before the hum left. I need to know if that is safe or not. Would the transformer get hotter? Seems to. Thanks !!!
#48
It shouldn't hurt anything to increase the value of the output filter cap. The transformer should not run hotter.
The extra hum was probably there all along since you did the conversion to a PM speaker; the 4 inch speaker, most likely, did not have the frequency response on the low end so that you heard it. The 6 incher obviously has a wider frequency response, so you started hearing the hum when you installed it. If the 16 uF output filter reduced the hum to an acceptable level, then you have done all you can.
Ron, would the 16 uf cause the transformer to overheat? It does seem to be running a little warmer. I don't want to burn out a transformer for want of less hum. What happens inside the radio when you increase that capacitor? Thanks !!!
#50
As I said, the transformer should not run hotter with the larger cap. If it does, then something is either drawing more current than it should, or else the transformer was already marginal (that is, possibly damaged) from old, partially shorted electrolytics and continued operation in that condition.
The transformer is not running overly hot. I think the difference is, on the last check the chassis was outside the case. This model does have a back on it, and there are a few tubes close to the transformer to increase the heat. Anyway, it's all good and I appreciate your responses.
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
There are currently 3984 online users. [Complete List]
» 2 Member(s) | 3982 Guest(s)
