Threads: 29
City: Richland, Michigan
I have a model 65 that has a modulation hum. The hum increases as a station is tuned in and fades between stations. I installed two Y type line to ground safety capacitors to each side of the power line. As well, I have an X safety cap across the line. The set is grounded to an 8 foot copper clad ground. Oddly the modulation seems nearly non existent at times. It really works well otherwise. Any suggestions would be appreciated. Thanks.
Threads: 92
City: Clayton, NC
Are there any neon lights on in your house when the radio is on?
Threads: 29
No neon or fluorescent lights on at the time. The line to ground and across line safety caps should eliminate most of that kind of interference
Threads: 40
City: Las Vegas, NV
Plasma or LCD TV? My Samsung Plasma puts out a bit of hash.
John
Las Vegas, NV USA
Threads: 29
No sir. We don't have a tv like that. It acts just as Elements of Radio Servicing describes on page 438 as modulation hum; silent between stations and hum when tuned in. I'm considering checking the chassis grounding post, but this model 65 is a heavy beast. It's very solid. It receives well.
Threads: 268
I'd check and tighten the ground connections on the chassis. Sounds like you might have a bad one.
Threads: 55
City: Evanston, IL
Also, your "Ground" source may not be realy Earth Ground.
If you're using the ground screw on an outlet, that may take a high resistance path to real ground and cause a "ground-loop" through your electrical system and cause hum. Depends on your house electrical system. Try a ground clamp to a COLD water pipe, clean, no-paint.
Chuck
Threads: 29
It's grounded with a single #14 gage wire screwed to an 8 foot copper clad grounding rod driven all the way into the earth. When I removed the wire it REALLY hums, but when it's connected it's hums moderately but too much.
Threads: 18
Wierd stuff sometimes happens on old sets, like a poor ground connection through a rivet or nearly crapped out antenna transformer or coil. Tapping around gently with a dry chopstick when there are problems just might lead you to a mechanical problem, if there is one.
Threads: 268
Something else came to mind if you still can't find it check your RF coils for (green primaries) corrosion. You may have a sightly bad coil that isn't giving you a good ground return for the grid of the tube. Also you could have a bad 24 tube. It could have a short from the cathode to grid 1 or a heater to cathode. If you've got a spare I'd swap it and see if that does the trick. Either 24 could be at fault. The pilot lamp may affect the overall amount of hum. It may have a bit more of less with or without it in the circuit.
Just a thought.
(This post was last modified: 10-21-2012, 02:03 PM by Radioroslyn.)
Threads: 1
City: Romulus, MI
Heater to cathode leakage in one of the tubes can cause this kind of hum, although it is not usually of an intermittent nature.
Threads: 18
Stating obvious again this evening, check antenna coil. Open will garble every time.
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
