  • 1 Vote(s) - 5 Average
16B cabinet
Hi Ron and all
Is this the correct toning of the 16B cabinet? I have my cabinet ready to spray (sides and top only) and need to ask if this is the correct toneing. Icon_confused
Joe
[Image: http://i927.photobucket.com/albums/ad118...co16B3.jpg]
Joe, It looks very good to meIcon_thumbup
M R Radios   C M Tubes
Thanks Steve Icon_wave
Joe
I did some searching on the web and this is the best photo I found of one with the original finish.
http://www.tuberadioland.com/philco16_ca..._main.html
The 16B which Bob linked to is a perfect example of another controversial subject - were the edges and trim toned dark, or not?
Like the top edge of the 620/623B front panel, some were, some weren't. No rhyme or reason.
Thanks guys. Ron which of the decals is correct for the 16B? From radio Daze. Joe
You want DCL-PH8 - and remember, they are now authentic Icon_smile
Looks downright Snazzy now.
Wr4rtc,That is a beautiful set!!
I can feel the 16's slowly sucking me into having to have one.........they are extremely impressive radios!
Gene
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
