39-7 pushbutton adjustment
This is a long shot, but does anyone have the push-button adjustment instructions that the schematic says were supplied with each set? The procedure may be obvious to some but I could use a hint. I have zeroed in on some stations, but there are 10 padders for 5 push buttons and I'm sure that I am not doing this correctly.
Your wish is my command. Icon_smile Point your browser here:
http://philcoradio.com/phorum/showthread.php?tid=5428
Ron, I'm almost speechless. As I said, I thought that it was a long shot. Thank you!!
Dave
Philco 91 Tuning Condenser
There are currently 5966 online users. [Complete List]
» 3 Member(s) | 5963 Guest(s)
