Proper toners for Philco 16B cathedral
Hi everyone,
I need to refinish a Philco 16B cathedral cabinet. I just need advice on the proper toners (Mohawk?) for this cabinet. What have you used that has worked well?
Medium Walnut for the main body of the cabinet; Perfect Brown (Ultra Classic) for the front panel. Just enough to give a two-tone contrast without going overboard.
There are currently 9814 online users. [Complete List]
» 1 Member(s) | 9813 Guest(s)
