RCA Victor R-15
Could someone with Riders volume 1 scan a copy of the schematic for the RCA Victor R-15 for me? I believe it is on 1-14 under RCA Victor.
The copy on Nostalgia Air is unreadable and Riders Vol 1 is one that I don't have.
Thanks
-Keith
It's also a Radiola 48. The big, heavy vertical TRF chassis, right?
Those sets must have been in a contest with the Baldwin Locomotive Company for weight. However, they were reportedly very good sets.
I'm sure I have the RCA Radiola 48 service book, but just where to look is the problem.
The early Victors are surprisingly GOOD receivers for TRF sets. I had an RE32 that had amazing reception. It had, if I remember correctly, FOUR RF amplifier circuits before the detector.
HOWEVER, the Victors are TOUGH to work on.
Keith, I have a copy of the R-15 from Vol I that you requested. Let me know how to get it to you.It is a pretty good copy.
Dave D
Ijust did a google search for: "RCA Radiola 48. It has the entire RCA service booklet with a clear full page schematic diagram, as well as the rest of the book.
Thanks Dave and Doug for the info.
I hope it turns out to be a good performer. I have had it for a few years now got it from my parents for a birthday present. It's missing the dial bezel which i have been hunting for since I got it. The cabinet is in good shape except for the veneer on the top is shot and will need to be replaced. The press wood looks very good.
-Keith
Keith: you might want to take a look at the radiolaguy website, he may have what you are looking for....
There are currently 6975 online users. [Complete List]
» 1 Member(s) | 6974 Guest(s)
