Philco model 39-5505
Hi Guys,
Has anyone ever seen or heard of a model # 39-5505?
I don't know what tubes are in it.
Eric
Eric
The Villages, FL
Nope. Could be the p# for the cabinet or a foreign model. Got a pic???
No such model. Most likely, a part number for the tube layout sticker - a common mistake, given the fact that Philco often printed the part number in large numbers on these tube layout stickers from about 1939 on.
Here's a pic. Any ideas?
Eric
The Villages, FL
OK, now we're getting somewhere. Icon_smile It could be any of the following:
38-38T (battery operated)
38-39T (operates from 6 volt battery)
38-40T (operates from AC or 6 volt battery)
Thanks, Ron.
Eric
The Villages, FL
So...don't keep us in suspense...which one of the four I listed did yours turn out to be?
It was just one I was looking at from a photo. One of the photos shows a power supply stuffged inside the cabinet so I think it is a 38-38T or 38-39T.
I'm going to pass on it.
Thanks for the help,
Eric
Eric
The Villages, FL
OK, I found it.
http://www.shopgoodwill.com/viewItem.asp...D=11911175
It's very cheap now at $13.99, but it will go up before the bidding ends.
And I think it's a 38-40T; that power supply sure looks like a 38-40 power supply. 38-40T models are not too hard to find and are neat little sets.
A side note: I see my Gallery has the wrong picture for a 38-22T which has the Cone-Centric mechanism like a 38-7T. I'll have to get that changed. I corrected my post above accordingly.
Last night when I was walking my dogs I looked up at the sky and the moon was BLUE.
Today we discover that the esteemed PhD (Doctor of Philcology) made a MISTAKE!
Is there a connection?
What does it all mean?
Icon_wtf
I'm sure now that everyone on the PHORUM knows about it the bidding will go up.
Thanks for the info,
Eric
Eric
The Villages, FL
Well, yeah; you did say you were going to pass on it. Icon_confused Besides, someone else here (not me) may want it.
A little while back someone on CL posted a Philco console for sale as a model 39-5505. Although they said they weren't sure that was the model.
Gene
You know that model 39-5505 is probably their most popular model!!! They made ALOT of them.
Philco 91 Tuning Condenser
There are currently 5983 online users. [Complete List]
» 2 Member(s) | 5981 Guest(s)
