Philco 70 Cabinet
Most Philco car radios, of the period, had the black rosette knobs,however some had brown ones. Kinda depended if the radio case was painted black or brown wrinkle finish.
I'll keep the black knobs, they are probably hard to find, but I think that I have some brown ones for the 70.
Phlogiston Wrote:Ron, could you bring that new truck over here to move some radios?
Sure, if I get to keep some of them. Icon_wink Icon_lol
Excellent job on the cabinet!
Chassis installed:
Philco 91 Tuning Condenser
