Threads: 50
City: York PA
When I bought this radio from a radio person, he explained away the following note as "probably caps": 80 tube overheats, do not energize until problem is found. So I took out the 80, and did some voltage checks. The voltages to the 80 were right on. Filaments to the other tubes OK. Field coil OK, choke OK. So I stick the 80 in and at around 80 volts, there are little sparks on the 80 tube socket (from underneath) and I quickly shut down. The 80ST shows shorts and no filaments.. I hadn't checked it before this. Now, before I start the lengthy (but enjoyable  ) recap, do my initial transformer checks rule out a transformer problem? Anything else to check first? Suspects?
What schematic do I want to be looking at? This chassis has a band switch; the on/off is with the volume. The electrolytics don't match up with 18 schematic. For example, I don't have part #s 59 & 60 (8uF & 10uF and 8uF), I have a 20/20/20 can.
(This post was last modified: 12-30-2012, 06:16 PM by DKinYORKpa.)
Bad 80 tube socket? This has been known to happen in Philcos of this vintage.
If it has two bands (AM and the "police" band), on-off with the volume control, then it is the early 18 - not the later Code 124 (AM only) version.
Threads: 50
City: York PA
Quote:then it is the early 18
Is this something that I have to get from The Philco Repair Bench?
Ah, I see what you mean - the early 18 isn't at Nostalgia Air.
Well, if you want good, clear, readable schematics with all production change notes, etc., then - yes.
Threads: 1
City: Utah
Well worth the 7.00 from Chuck.
Threads: 50
City: York PA
Quote:Bad 80 tube socket? This has been known to happen in Philcos of this vintage.
Electrolytics this time.
Quote:Well worth the 7.00 from Chuck.
Check went in the mail today.
DKinYORKpa Wrote:Quote:Bad 80 tube socket? This has been known to happen in Philcos of this vintage.
Okay, just trying to help...good luck...you may need it.
Threads: 50
City: York PA
Quote:Okay, just trying to help...good luck...you may need it.
I love your help! Now, why may I need good luck??????
Threads: 112
City: Medford OR (OR what?)
If you saw sparks in or under that socket and it is a wafer style, then you better keep an eye on it after you are done. Any arc will burn a trace between the layers of the wafer resulting in a HV short that just gets worse.
And that was the point I was trying to make, DK! Phlogiston is 100% correct.
Now, let's all go put some extra Chivas Regal in our New Year's drink for this evening and have a nice night.
Threads: 112
I still have a transformer to wind. Will Chivas Regal help - you know it will!
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
