tranistone speaker
New guy here and new to redoing old radios. I picked up an transitone 42-PT-96 to start on. It plays but the original speaker cone is gone and someone placed an 1 1/5" (permanant magnet) speaker in it. Anyone help with a part or type number or point me in the right direction? Could also use a schematic. I can find PT-88 through 95 but no 96.
Thanks
You will find a copy of the schematic here:
http://www.nostalgiaair.org/PagesByModel...014179.pdf
Carl
Northern Panhandle, WV
Thanks Carl.
I have been told that I can replace the speaker with a PM type and replace the field coil with a 10 watt resistor in the 500 ohm range. Does this sound right? The schematic does not list a value on the field coil.
Scott
Scott,
The PT-42 schematic is similar to the PT-96 and it shows a value of 500 ohms for the field.
If you use a PM speaker, you will need to also use the output transformer from the original speaker.
If your old speaker just needs reconed, many people recommend Hank Brazeal. Contact info can be found in this thread:
http://philcoradio.com/phorum/showthread.php?tid=229
Carl
Thanks for verifing that. The speaker cone was missing when I picked the radio up but the field coil and output transformer where there. I have 8 other radios that I like to listen to but have noticed their performance decreasing through use. I picked this radio up on ebay for practically nothing to practice my restoration skills before digging in to the others but found it in better shape than I thought. Would like to restore it to it's original glory. Still looking for an original speaker before I go that route.
Scott.
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
