hum in 116B
I have acquired a hum in my set.
I was going to sell it but pulled it.the shadow meter seems to want to work but does not. moves slightly left or right and stops.
I think it used to work before. If the hum was from a power supply filter,it would be there all the time wouldn't it?
this hum is only on station and in between stations there is no hum.
Does the shadow meter work off of an IF tube?
Where do I start.
David F
Thanks anyway-I will sell it as is.
Many things can cause weird noises in vintage radios. If you havent changed the filter caps yet, that is most likely the source!!! However, common household items such as modern type florescent-lighting near your radio, TVs that are turned on, microwave ovens, clothes washers ( motors put out RF!!), clothes dryers, AC line "hash" coming into your home ( hence, a neighbor down the street firing up his home arc-welder connected to the same overhead pwr lines), ALL cause static & weird hums in vintage tube radios especially if on or near each other at the same time. If the radio has had a complete "re-cap", check your surroundings , turn off all other electrical appliance devices, and try again. If the radio hasnt had a complete recap, the old "filter caps" are telling you to unplug the radio, and sell it before you take-out a pwr transformer, ( if it has one). Just trying to help. Randal
Rich Those are exact same I used before. I just recently bought these from Mouser. DE2E3SA103MN7AT02F It is exac...morzh — 09:16 AM
Morning, Ron! Yep, that’s the Moyer I spoke with. They did say that they researched for any off-brand equivalents but di...jrblasde — 08:51 AM
Joseph, the Moyer Electronics I’m familiar with is in Pottsville, PA. Only a half hour from me. My dad used to to buy fr...462ron — 08:24 AM
Thanks, everyone! I suppose I’ll keep these installed since I have them and they do fit. But moving forward I’ll know th...jrblasde — 07:57 AM
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
There are currently 3486 online users. [Complete List]
» 4 Member(s) | 3482 Guest(s)
AvatarAvatarAvatarAvatar
