  • 1 Vote(s) - 5 Average
Atwater-Kent model 46 console
Hmm, I meant to ask. Is the speaker in that unit an Electro-Dynamic type? It doesn't look like the usual AK high impedance design I've seen in some of these consoles over the years. Well, in pictures.
Yes, it is an electro-dynamic speaker.
Should sound good them. I pulled up some schematics and it mentions a small model 53 console using this speaker, so that means the radio is set up for it. Might not be huge sound, but push-pull 71s sound pretty good when the unit is set up right.
There are currently 3166 online users. [Complete List]
» 1 Member(s) | 3165 Guest(s)
