40-216, 41-316 and similar sets - WHAT'S WITH THE HOLE?
I recently acquired a Philco 40-216 with remote control. The cabinet has a hole about 3/8" in diameter in the center of the cabinet right below the fold-up cover. I looked at other similar sets such as a 39-45, 41-316, and 39-116 in various galleries and they ALL seem to have the same hole. It looks like something is MISSING. But WHAT? And why do ALL sets I have seen have this hole?
Does anyone know what might be missing and have a photo?
Thanks
Very simply, a pilot light. There was a plastic jewel that went in there. I use to have a 42-1015. I used to be able to get red jewels from when I was in the vending business years ago. It was for a "use coin only" light. I used the little piece from the top of a red Bic pen in some cases now. It's not transparent like the originals but works. The originals disintegrated and turned to powder which is why they are always missing.
There are currently 8883 online users. [Complete List]
» 1 Member(s) | 8882 Guest(s)
