needle/stylus and cartridge for 47-1227
does anyone know where i can obtain a needle/stylus and a cartridge for a 47-1227's phonograph. thanks!
Try http://www.west-techservices.com/ .
Thanks, Ron!
Philco 91 Tuning Condenser
There are currently 8665 online users. [Complete List]
» 2 Member(s) | 8663 Guest(s)
