Philco 95 cap questions ( more)
Ok folks on the rest of the caps in the set.
I gather that the 3788A is a .015uf
3584B is a .05
what is the 3787A part.
Thanks
3787A is an .05 cap with a 250 ohm resistor.
This info is from a Chuck Schwark post on ARF:
The phenolic tube has three terminals; the ground mounting lug which one end of a 0.05uF/400 volt cap. The other two terminals are the junction of the cap and 250 ohm, 1/2 watt resistor. The remaining lug is the other resistor end. A simple ohmmeter test can determine which is which.
Carl
Northern Panhandle, WV
Thanks, I had for got about the cap+ resistor together
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 8968 online users. [Complete List]
» 1 Member(s) | 8967 Guest(s)
