Zenith 6D-815
I have a Zenith Model 6D-815 that came out of my sister's estate and as I was looking it over I noticed the electrolytics were replaced at some point as were all other capacitors. I discovered two of the tubes weren't up to snuff after checking them out in my EICO 625 and replaced them.
It has a real scratchy volume and stations weren't very perceptible...only a few and the volume control was stiff. I sprayed contact cleaner in it and it's still stiff but I can get 4-5 stations but not all that clear due to the sound of eggs frying, particularly between stations.The volume acts like it wants to go up but doesn't unless you purposely turn it up. It's like something's not making contact somewhere. There were no burned resistors Anything else to look for?
Probably the elecrolytics need to be replaced as a bare minimum. I would not power it up again until this is done. If the paper capacitors haven't been replaced, I would do 'em all, and probably all the carbon resistors as well, as it will only be pennies apiece and should be done all at once. Also I would apply a tiny amount of WD40 to each switch and control bushing, and give all contacts and control innards a nice spray with Deoxit 5, and let dry overnight. I'd probably clean out tube sockets and pins with a little Deoxit on a pipe cleaner, and check for firm contact with tube pins. Could also be dust or whatever on Tuning Capacitor, and a blast to Deoxit usually does it, but if there is a lot, a piece of paper can usually dislodge it. Be patient, this takes a few moments.
Let us know.
It was the electrolytics. Apparently they don't last as I long as I thought. These couldn't be more than about 10 years. I don't have any De-Oxit so,I sprayed the tuning capacitor first, then I had already sprayed the volume control but squirted a little WD-40 on the outside of the control. I need to swap out the tube contacts. Being a pipe smoker, I have plenty of pipe stem cleaners. Thanks for the suggestions. An alignment probably wouldn't hurt either.
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
