39-30 plastic dial cover
does anyone know where i can get a plastic dial cover for a 1939 model 39-30? thanks!
You might try Radio Daze:
http://radiodaze.com/reproplasticdials.htm
Carl
Northern Panhandle, WV
...or West-Tech Services, which recently purchased Doyle Roberts' dial cover business...
http://www.west-techservices.com/
...or Bill Turner...
http://www.dialcover.com/
There are currently 8700 online users. [Complete List]
» 4 Member(s) | 8696 Guest(s)
AvatarAvatarAvatarAvatar
