New guy, with a Philco question.
Hi. Thanks for having me.
I just purchased a Philco PT-7 for $20. Can somebody tell me a little about this radio? I'm assuming the P stands for Philco., the T stands for table, and the 7, I have no idea.
Thanks you.
Welcome!
Look here for more info on your set:
http://www.philcoradio.com/gallery/1942a.htm#bi
Scroll down to near the bottom of the page.
The full model number of your radio is 42-PT7. Yes, P stands for Philco; but T stands for Transitone. The 7 is merely part of the set's model number.
Thank you very much.
Philco 91 Tuning Condenser
There are currently 8928 online users. [Complete List]
» 2 Member(s) | 8926 Guest(s)
