Antenna for 39-116
Hi
I need an in-the-cabinet antenna for my 39-116. I don't think it came with one when new.
What do you suggest?
Thank you very much.
Hi
Model 39-116 was not manufactured with a loop antenna; it was designed for a longwire. Of course the "Mystery Control" section of the receiver DOES have a loop antenna, built into the bottom of the cabinet.
Some people have made their own in-cabinet loops for consoles. Some of these folks report good results. YMMV. I would opt for the longwire, or at least a short length of wire stretched across the baseboard of one or two walls.
Thanks much for the info. I had a feeling that was the way to go.
Regards,
Lew
Philco 91 Tuning Condenser
There are currently 5192 online users. [Complete List]
» 2 Member(s) | 5190 Guest(s)
