Philco 38-10 Q
I just got started on my 38-10 and have a quick question. The face of the cabinet, is that a "photo-finish"? Meaning, if I start stripping the face of the cabinet will I lose the grain pattern along with the three light color inlays?
Thanks in advance!
Ok, I did a little research and it is a photo finish. Luckily it isnt too bad so I will do some light sanding, sealer, toner and then clear...
Be very careful sanding photo finish.
I have had good results using 0000 steel wool on photo finish. The object is to clean/smooth the old finish, then spray clear lacquer over it.
New member
Philco 630csx power cord
New member
There are currently 4038 online users. [Complete List]
» 1 Member(s) | 4037 Guest(s)
