Transporting a 37-116
So, as many of you know, I am on my way to pick up a 37-116 tomorrow. It's about a 3.75 hour drive each way, mostly smooth Interstate travel. The radio will be lying flat on its back in the back of my Ford Taurus X. Here's the question: should I remove the radio chassis before transporting it? I doubt a radio like this was designed to be transported in this manner and I don't want to damage anything. If I do need to remove it, what tools do I need and how hard is it?
If in doubt remove chasis, being carefull to unplug speaker if possible, wrap all in old blankets and drive like a hearse. Other opinins welcome.
On thing to be very careful about, you can damage the veneer when sliding the cabinet in and out of the car. If the veneer catches when sliding it will flake a piece right off.
M R Radios   C M Tubes
Jontz
If the Philco dealer left the "J" bolts in place when the set was sold to the original owner, and then assuming subsequent repairmen also left them in place, then you might get away with transporting the set intact.
But I wouldn't do it, even if the chassis is still bolted in with those special "J" bolts - and chances are that it isn't. The "J" bolts were supposed to be removed when the dealer delivered the new 37-116 to the original owner, with the chassis left to "float" on the original rubber washers which are likely also gone with the wind.
In short - do remove the chassis, and the 14 inch speaker. Your back will thank you.
IMPORTANT NOTE
Be very careful when removing the large speaker! There is a conical piece of wood in front of the cone. One wrong move and you'll tear up your speaker's cone! I suggest removing the chassis first - remembering to unplug the speaker wiring harness from the back of the speaker - and then laying the cabinet face down on a thick blanket. Remove the two bolts and nuts holding the speaker in place on a wooden support, and then carefully pull the speaker straight out (NOT "up" as in "up toward the top of the cabinet" but OUT (as in "straight back"), as much as possible as the wooden support which holds the speaker in place will interfere somewhat.
One more thing. Early 37-116 models have five individual push pins that connect at the audio output transformer, mounted on the back of the speaker. You'll have to remove a cover where the wires go into the audio output transformer, make notes of which wire goes where, and then just pull each one out. Later models use a five-contact socket and plug; the socket is on the speaker wiring harness, and the plug is mounted on the back of the speaker. Check for the presence of a screw which may be holding the socket to the plug and remove if necessary. You'll recognize this by the telltale screw head at the back of the socket where the wires come out and go to the radio chassis.
Be careful, be safe, follow the suggestions given by Codefox, Steve, and myself - and enjoy your "new" find! Icon_thumbup
Thank you everyone for the information and advice, I really appreciate it!
Make sure you post some photos here! That is quite a find!
Make sure the speaker is bolted down before you move or tilt the cabinet or like Ron said it will destruct the speaker. Don't ask me how I know. Seems like you can't remove the speaker before you remove the chassis. It won't clear the bottom edge the chassis.
It made it home safe and sound! I'll post some pics once I get it unloaded and have the time. Thanks again everyone!
Philco 91 Tuning Condenser
There are currently 5394 online users. [Complete List]
» 1 Member(s) | 5393 Guest(s)
