Original cabinet finish
I am gathering supplies for my 48-1262 restoration, and I am wondering what the original finish was--gloss or semigloss?
From looking at the photo gallery the finish looks like it's gloss.
-Keith
That is what I was hoping. Gloss it is.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
