Proper decal for PT7?
Mine is crooked and, I'm not sure it is correct? What should it be/look like and, are they available?
Thanks.
Courtesy Richard Lackie:
[Image: http://www.philcoradio.com/gallery/image.../42pt7.jpg]
Not sure if Radio Daze carries this decal? Antique Electronics Supply has a PHILCO decal sheet but I do not recall if TRANSITONE is on the sheet.
There are currently 9549 online users. [Complete List]
» 1 Member(s) | 9548 Guest(s)
