interchanging chassis and cabinet
Do you think a philco 60 (360 chassis and code 121) cathedrel chassis will fit a philco 37-60 cabinet? I'm not sure if the knob holes will fit , they look squat.
It will not fit. Chassis holes for Model 37-60 are spaced farther apart than for Model 60; not to mention the smaller dial used with Model 60 versus Model 37-60.
Thanks Ron, figured so.
There are currently 9807 online users. [Complete List]
» 1 Member(s) | 9806 Guest(s)
