Philco 70 cabinet woes
Hi to all. I recently received some help on this forum with a 640B I am working with, so I thought I'd run this one by everone in hopes someone will have an answer. I have a model 70 that has several inches of veneer missing on one side of it. I can't tell if it's mahogany or walnut. I understand both types of wood were used on this model for sides and top. Is there an easy way to tell what type of wood I may have ? Also, is there a source for veneer that anyone knows of? I need a piece 7" X 10" to fix my cabinet. Any help would be appreciated.
Hi
Take a good look at your cabinet...if you see a hint of red in the wood, it is mahogany; but if you only see shades of brown, it is likely walnut.
I suggest a Google search for "veneer." Constantines and Van Dyke are two possible sources. As a general rule, veneer can be hard to find from local sources.
Hi guys,
If your cabinet is mahogany, you might be better off to replace the complete wraparound. I have done this on a couple of my cabinets. A good source of 1/8" mahogany ply is Airccrft Spruce and Specialty.
M R Radios   C M Tubes
Philco 91 Restore Code ??
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 6409 online users. [Complete List]
» 1 Member(s) | 6408 Guest(s)
