Automatic Tuning Dial Station Call Tabs
Does anyone here know if/where I might be able to locate new or used station call tabs for my 37-116X ? Almost all of mine are missing. Icon_sad I know that Philco sold them as a separate kit once upon a time...... If only I could just call them up and order some now!
These are hard to come by and are usually broken or rotten. You might try some clear plastic and some paper printed in the general brown/orange color
I won a set from ebay awhile ago and have a bunch of them left. I have a bunch of different call stations. Send me your want list and I will send them to you.( tuberadiophile at aol dot com)
Chris
There are currently 9440 online users. [Complete List]
» 2 Member(s) | 9438 Guest(s)
