Non AA5 Philco's
Greetings,
I would like to know if there are later model Philco's table models that have the power transformer in them. By later I mean late 40's and 50's.
Andy
The 48-482 has a transformer/rectifier. So do the 3123 and 3472 Tropic models that were made in the late 50s.
Thank you. I can't find anything on the 3123 or the 3472. Are they both model numbers?
Yes, they are. But you won't likely find much on these two, since Tropic models were intended for export so are difficult if not impossible to find in the USA.
Thanks Ron...
Philco 91 Tuning Condenser
