Lamp for Philco 46-427
The schematic for this set calls for a I100 bulb for the panel light. It is a bayonet type but not a 44 or 47 6 volt bulb. Anyone knowe what it is? Thanks - Joe jdgatto@earthlink.net
Joe,
P/N 34-2068 is supposed to be a type 47 bulb:
http://www.philcorepairbench.com/lamps.htm
Carl
Northern Panhandle, WV
Thanks Carl. I see my mistake now. When I first tried a 47 it blew out immediately, probably a fluke. I then went to a 44 but that draws too much current. Will go to radio shack and pick up another 47 and try again. Joe
I100 is the schematic/parts listing designator - Indicator (lamps) 100.
Just like L for coils, T for transformers, C for caps, etc......
Chuck
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 8192 online users. [Complete List]
» 1 Member(s) | 8191 Guest(s)
