Coin Operated Philco
Anybody seen one of these before? What model # is it?
http://cgi.ebay.com/110193292345
Thinking of bidding on it.
Chris
Not a radio issued by Philco, it has one of the compact prewar Transitone chassis inside a coin-op cabinet made by a different manufacturer. The radio was obviously modified to operate with the coin-op mechanism. The loop antenna isn't even original.
There are currently 8894 online users. [Complete List]
» 1 Member(s) | 8893 Guest(s)
