Latest CL Find ....A Zenith 7s366
After several months of communications, planning etc.(December -March) my acquisition of the Philco 38-116 fell apart. I had arranged the day to go pick it up along with this radio. When I lost the Philco, I debated on whether to go ahead and make the trip to see this one. Finally decided it was worth a look and when I saw it I figured I really had to have it. I had not seen this cabinet before and the look of it really got my attention. It is like a very fine piece of furniture.
It has some issues, but nothing I don't think can't be restored.
[Image: http://i1185.photobucket.com/albums/z345...120add.jpg]
Gene
Looks nice. The cabinet seems to be in a very good shape. To me this is what matters most.
Nice! Not an often seen model.
Good score! I have the much more common 7S363. Same chassis, I believe.
Mike
I have the 363 also but I like that "filigree" carving at the top of the cabinet. Does it extend around on the side clear to the back? Nice.
The "filigree" is only on the front.
Gene
There are currently 7745 online users. [Complete List]
» 2 Member(s) | 7743 Guest(s)
